1/13/2021 4:59 PM | |
Joined: 12/12/2016 Last visit: 4/8/2024 Posts: 640 Rating:
Hello, It shows "offline" if no new datapoints have been sent for a longer while. Have you tried publishing a new value? You can find a detailed description on how to onboard an configure an asset on here. Depending on the vesion of the mindconnect node that you are using (you can check this in the node-red palette) you can select the specific version in branches/tags: e.g for V3.7.0 this would be the correct README. Best Regards |
