9/24/2013 1:14 PM | |
Joined: 4/3/2013 Last visit: 12/15/2023 Posts: 7 Rating:
Hello Automatan, check please the Rack.Nr of Master and Standby PLC. Master must have Rack number 0 and the Standby PLC Rack number 1.you find a switch on the back of the PLC'sfor thisRack number adjustement. ckeck please the correct connection and setup of Sync-modulesand possibledefective modules (e.g. curved connection pins of Sync modules) Note: if you use the old Sync-Module, the closing cover must be permanently attached with th Sync-module in order to activate the micro switch of Synch modules. Please use also the Service Request from Online Support for more Details. http://support.automation.siemens.com/WW/view/en/16605032 |
