12/17/2018 11:09 AM | |
Posts: 80 Rating:
Thank you. I'll wait for cable. Next i'd comment here |
12/20/2018 10:04 PM | |
Joined: 9/27/2006 Last visit: 7/17/2024 Posts: 12268 Rating:
Hello runaway7; Look at the information provided by member Azteke0110 in th following link: Since production of the Siemens S5 cables 6ES5734-1BD20 and 6ES5734-2BD20 has been cancelled and they are now available only as spare parts,, the suggested Koster-Box would be a good alternative for you, for an "active" cable. Another option: IBHSoftec develops S5 and S7 for Windows, programming software for S5 and S7 PLCs, and also provides communication hardware you could examine. See for example the following cable descriptions: - IBH S5 adapter : https://www.ibhsoftec.com/epages/63444704.sf/en_GB/?ObjectPath=/Shops/63444704/Products/2020 - IBH USB-S5 adapter : https://www.ibhsoftec.com/epages/63444704.sf/en_GB/?ObjectPath=/Shops/63444704/Products/20220 Hope this helps, Daniel Chartier |
12/21/2018 4:30 AM | |
Hello runaway7; The available cables mentioned above are active RS232/TTY cables. The following search results show various RS232/TTY passive cables (or active/passive, selectable) cables from different manufacturers: RS232/TTY passive cables - Google Hope this helps, |
12/21/2018 7:30 AM | |
Posts: 80 Rating:
Guys . Its active cable . Thats why i couldnt download in op15c1. I would find the passive cable and inform you all. Thank you |
