12/23/2006 11:41 AM | |
Posts: 17 Rating:
You have to have MPI down load cable .The same cable which you use to Download the S7-300,400 plc program. thanks |
12/27/2006 8:53 AM | |
Joined: 4/24/2006 Last visit: 6/20/2024 Posts: 8684 Rating:
Hello serkan_boz, The mentioned cable is correct. You'll have to put OP3 in Transfer mode serial. ![]() Another option is to download using MPI. In that case you'll have to put OP3 in transfer mode MPI. Here is a link to manual: http://support.automation.siemens.com/WW/view/en/1142799 Best regards, Wizard |
