6/14/2010 6:22 AM | |
Joined: 5/28/2008 Last visit: 7/4/2024 Posts: 4510 Rating:
Hello, Please have a look on the message list of OP7 in page B-15 0f the following manual: http://support.automation.siemens.com/WW/view/en/1145112 Hope this helps. |
Ayman Elotaify |
6/14/2010 8:02 AM | |
Joined: 3/21/2006 Last visit: 4/25/2024 Posts: 10228 Rating:
Hello, Look at SIMATIC HMI ProTool How to configure text-based units . About cable which you are using - MPI cable goes together with MPI adapter. Best regards, Hristo Mihalev |
6/14/2010 8:25 AM | |
Joined: 4/19/2008 Last visit: 6/25/2024 Posts: 1525 Rating:
Hi, you can used the Profibus Connector & Profibus Cable for the OP & PLC Communication, or if you are using the home made then connection must be 3-3 5-5 & 8-8 |
Ammy |
