5/30/2023 7:50 AM | |
Joined: 5/6/2022 Last visit: 7/31/2024 Posts: 437 Rating: (85) |
Hi FranCP, Could you offer us some more information? What exact WinCC version are you using? What is the error you are experiencing, can you describe it or provide an error message? Have you configured a new server, changed WinCC version, migrated or made any changes to start giving you these error logs? We await your response to see if we can help you. Best regards!
6/21/2023 9:48 AM | |
Joined: 8/3/2009 Last visit: 8/6/2024 Posts: 13467 Rating: (1704)
Hello FranCP Which connectino parameter do you change? or does WinCC Change back to wrong values? you can try to delete the temporary data of the project perhaps it helps: https://support.industry.siemens.com/cs/de/en/view/109763043 Bye Murof |
Last edited by: Murof at: 06/21/2023 09:48:37If this Information really helps, you could use the Rate function |
