3/16/2010 7:32 AM | |
Posts: 17 Rating: (0) |
Tried your solution, transfered a license that that works on another computer, but I still can't connect to OPC server. Thanks for trying LinasD. |
3/16/2010 1:16 PM | |
Posts: 4 Rating: (0) |
Which WinCCversion did You use? Which WinCCSP is insalled? |
3/17/2010 7:05 AM | |
I'm using Wincc V6.2 SP2 |
3/17/2010 7:19 AM | |
Hy I get such answer from Siemens support: //------------------------------------------------------------------------- Which WinCC V6.2 did you use ? Is it the WinCC V6.2 SP2 ? Our development known this case and for this we have get a Hotfix to solve it. In the newest WinCC V6.2 SP3 it is fixed too. So please upgrade to the SP3 of WinCC V6.2 . //------------------------------------------------------------------------- You can try to install this hotfix: ftp://audsupport:quoo4Ueg@ftp.sbs.de/20100222_1620209.zip Or try to install SP3 |
