3/7/2024 3:11 PM | |
Joined: 3/7/2024 Last visit: 3/7/2024 Posts: 1 Rating: (0) |
Hi CoenvdG, Could you tell me how do you manually allow the certificates of the partner? ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 03/18/2024 08:56:09New subject after splitting |
3/15/2024 10:17 AM | |
Joined: 8/3/2009 Last visit: 9/6/2024 Posts: 13594 Rating: (1720)
Hello there are folders for the OPC UA Server and Clients ou can see it documented in the Help System: https://support.industry.siemens.com/cs/ww/en/view/109813307/129276625675 There are always rejected and certs folders. to trust a rejected certificate from a partner you have to cut&paste (move) the certificate from rejected to certs folder Bye Murof |
