4/2/2024 3:15 PM | |
Joined: 9/27/2023 Last visit: 4/8/2024 Posts: 2 Rating: (0) |
Reminder if someone can help. |
4/10/2024 8:28 AM | |
Joined: 8/3/2009 Last visit: 10/31/2024 Posts: 14079 Rating: (1765) |
Hello AutoGen_3680652 so what is your usecase, what do you want to dio with the OPC UA Server? The Export of the XML file is for Clients that cannot use the browsing interface, and a Compenion Spec is also a different topic. Perhaps with a few more information what you want to do exactly we can help with better fitting answers. here are some basic information: https://support.industry.siemens.com/cs/de/en/view/109737901 https://support.industry.siemens.com/cs/de/en/view/109755133 bye Murof |
