11/16/2021 2:36 PM | |
Posts: 3 Rating: (0) |
hello ı have a final thesis ,so ı decided to use opc with tiaportal but ı couldn't find a how can ı add opc ua ? |
11/16/2021 4:22 PM | |
Joined: 3/2/2016 Last visit: 5/29/2024 Posts: 72 Rating: (14) |
Hi mechatronicstudent, First you have to make sure that your CPU supports OPC UA: How do SIMATIC and SITOP products support communication via OPC UA? Then if your CPU is the server, you have to activate it in the hardware configuration (Click "OPC UA > Server" in the properties of the CPU) and select your OPC UA certificate. By default, the OPC UA server of the CPU is not enabled for reasons of security. |
