7/9/2010 1:10 AM | |
Posts: 10 Rating:
can you read real numbers(make a data block with real number data type) CP is the master (client) reading data from bently nevada |
7/12/2010 7:03 PM | |
Posts: 10 Rating:
turns out you don't need to use an array in the Datablock. manually configured the db in scl source code and it works fine. |
