12/7/2017 5:35 PM | |
Posts: 39 Rating: (0) |
What is the difference between Analog output channel and Sensor line output on 6ES7135-6HD00-0BA1 analog output modules? |
12/12/2017 4:35 AM | |
Joined: 9/27/2006 Last visit: 4/28/2024 Posts: 12257 Rating: (2665)
Hello master_blaster; As was explained by CaOd earlier, the sensor lines are used for compensation wiring only. Have a look at the extract from the ET 200SP AQ 4UT manual blow, and examine how and when the sensor lines are required in an output circuit: https://support.industry.siemens.com/cs/fr/en/view/59753612 Hope this helps, Daniel Chartier |
