8/7/2015 9:56 AM | |
Posts: 13 Rating: (0) |
It`s DB I set "Actual value", after receiving the pulse - everything is 0 :( I don`t understand why is that. |
8/7/2015 2:16 PM | |
Joined: 1/28/2009 Last visit: 5/20/2024 Posts: 6840 Rating: (1359)
Hello, If you have no problem in pulse creation , copying your data into a buffer temp and then transferring them to target area would be much better.You need to use positive/negative edge detector to ensure only One time operation during the pulse.Check the attached file ! I hope this helps, hdhosseini Attachment1.zip (138 Downloads) |
8/9/2015 8:26 PM | |
The script not work. When i receive pulse, the controller switch "RUN" --> "STOP" :(.
I don`t know what`s the problem? Maybe Move block after Move block?
AttachmentProblem.zip (129 Downloads) |
