9/3/2014 10:46 AM | |
Posts: 262 Rating:
HI, Connect PAC 3200 to a switch take it to your LAN. On PC load Sentron Power Manager Software and Also install its web license and give an Static IP to that Server. You can monitor the same thru' internet explorer. Refer the below link for more understanding.... https://support.automation.siemens.com/WW/llisapi.dll?query=powermanager&func=cslib.cssearch&content=adsearch%2Fadsearch.aspx&lang=en&siteid=csius&objaction=cssearch&searchinprim=&nodeid99=&redir=false&x=35&y=3 |
9/9/2014 1:02 PM | |
Posts: 2 Rating:
Ok so solved this with Raspberry Pi, installed pymodbus and using address map table from PAC3200 pdf manual. thanks! |
