7/31/2023 11:51 AM | |
Joined: 8/3/2009 Last visit: 10/18/2024 Posts: 13982 Rating: (1760)
Hello GazaFso_Automation there are a few requirements for using Pack&Go: - Simatic Prosave - Microsoft Visual C++ 2010 Redistributable Package (x86) - Microsoft .Net Framework 4.5 https://support.industry.siemens.com/cs/ww/en/view/109476153 or for newer Version for example in V18: https://support.industry.siemens.com/cs/ww/en/view/109815056/94241254795 --> but Its important to install Prosave on this PC (in order to use the communication drivers to the Panels) -> A little bit less compicated alternative would be a offline transfer witout Pack&go: https://support.industry.siemens.com/cs/de/en/view/109740696 Bye Murof |
Last edited by: Murof at: 07/31/2023 11:53:36If this Information really helps, you could use the Rate function |
