3/8/2024 3:43 PM | |
Joined: 7/19/2022 Last visit: 11/15/2024 Posts: 420 Rating: (71) |
Hello At the SINAMICS S210 there is no default password for the user "Administrator". At the first Login with "Administrator" you need to assign a password. So if you don't know the password you need to reset the SINAMICS. This is also described at following link: Logging on for the first time and assigning an administrator password |
