2/10/2011 10:37 AM | |
Joined: 4/29/2010 Last visit: 4/30/2024 Posts: 1557 Rating: (161)
Hello,
Yes this is the only way in ProTool. The passwordlist at the panel there you have add users in runtime can`t be migrated to flexible because just project files will be migrated.
This isn`t possible, searching objects are possible with flexible. It would be the best to migrate the project and then search for the protected objects.
Not all security settings will be migrated, for example you must give the users new passwords because they wouldn`t migrate to flexible. I advice you to take a look at this manual, there you find all informations about the migration from ProTool to WinCC flexible: http://support.automation.siemens.com/WW/view/en/18796902 best regards. |
