9/27/2010 12:10 PM | |
Joined: 3/22/2010 Last visit: 4/17/2025 Posts: 76 Rating:
Hi Guys, My client has cable for connecting PC to S7-200 - 6ES7901-3DB30-0XA0. While unplugging cable, he accidently broken off the RS plug. Now he has a problem how to connect cables that he tear off. Do You have any cabling/wiring scheme of this device to help him fix it? Best would be wire color - pin number ralation. Thanks in advance. |
9/27/2010 12:50 PM | |
Posts: 101 Rating:
Hi, The pining you can find in the S7-200 system manual in the link above..
The PPI cable is a simple data-driven RS232-RS485 converter, powered by the PLC. The pin configuration for the RS232 side is:
2 thankful Users |
9/27/2010 1:05 PM | |
Posts: 101 Rating:
The attached might be helpful. Thanks, Attachments7200cableEnglish[1].pdf (3643 Downloads) |
2 thankful Users |
9/27/2010 1:10 PM | |
Posts: 101 Rating:
Setting the PG/PC interface config for the baud rate: https://support.automation.siemens.com/WW/llisapi.dll?func=cslib.csinfo&lang=en&objid=11870489&caller=view Thanks, |
9/27/2010 3:37 PM | |
Posts: 2930 Rating:
If you can connect to PLC, the you can reset the PLC with the PPI-cable using Wipeout.exe. This tool you can find on the MocroWIN CD ROM. Hopw this helps |
9/28/2010 6:32 AM | |
Posts: 18 Rating:
Dear radekk, I have also same problem as well as like you at this time i have notdown pin configuration So, i will send you this configuration in attachment(pdf file) pls find it. AttachmentUSB_PPI ADAPTER 9-PIN D-TYPE CONNECTOR DETAIL.pdf (2539 Downloads) |
5 thankful Users |
11/21/2015 6:25 PM | |
Posts: 1 Rating:
Thanks for your info. I have a problem with my cable, but it's PC/PPI cable type. Somebody had cut 9-pin D-Type male connector (to PLC). So, i can't find it again. I just bought a new connector. Tomorrow, i'll try follow your way. Thanks! P/S: Colors of cable: Black, Brown, Red, Ogran, Yellow, Green. Truong Nhat. |
Last edited by: NhatBui at: 11/21/2015 6:37:39 PMLast edited by: NhatBui at: 11/21/2015 6:40:24 PM |
7/26/2017 10:45 PM | |
Posts: 2 Rating:
Hello Group: I was wondering if there was ever a post defining the pinout by means of wire color to pin. I have the same situation as pictured above where the connector (to the plc) has broken off completely with no reference as to which wire went to which pin. Many thanks in advance. |
7/26/2017 10:49 PM | |
Posts: 2 Rating:
And for clarification the adapter that I am working with has the following part number. 6ES7 901 3CB30 0XA0, RS232 / PPI Multi Master |
