2/2/2024 7:45 PM | |
Joined: 3/14/2008 Last visit: 5/14/2024 Posts: 2066 Rating: (928)
Hi, You can use the Operator Authorization column in the properties of the Interlock block. In there you can set a level 1,2,3 where 3 means higher clearance for each BypInxx signal. See attachment. |
