6/11/2015 11:56 AM | |
Joined: 11/29/2011 Last visit: 5/20/2024 Posts: 1358 Rating: (231) |
HI, Why do not you create a customized PID Process Tag Type in you Master Data Lib in which you remove the Chanel driver? See this manual SIMATIC Process Control System PCS 7 Advanced Process Library (V8.0 SP2) page 1800 about how to use Process Tag Types. Alternatively you could use the Chanel Driver from the PID Process tag Type elsewhere in your code. Or merge the two Process Tag Types as recommended above. Keep in mind the block execution order! What do you think? |
Last edited by: MicroMan at: 6/11/2015 12:02:13 PM- What you read here, please check with manuals and your requirements. |
