8/28/2019 9:15 AM | |
Joined: 5/3/2017 Last visit: 5/21/2024 Posts: 673 Rating:
Hello ysa, the sending and receiving SMS messages is not tested and released for PCS 7. So, if you used it and run into problems Siemens will not able to help you. In the application example Sending and receiving SMS messages with serial CP or CM and MODEM MD720 you can find an example for STEP 7 V5.5 which PCS 7 use. With regards |
