9/9/2012 3:32 PM | |
Joined: 3/14/2008 Last visit: 11/19/2024 Posts: 2134 Rating: (955) |
Cant you just use the nested CFC function? Two interlock blocks connect to motorblock with logic: interlock 1 for direction A, 2 for direction B, then compile as block type? |
