8/13/2019 8:26 PM | |
Joined: 2/24/2015 Last visit: 1/25/2023 Posts: 306 Rating: (77) |
16#60 means that the value is simulated, the status of the value should be 16#80 |
8/28/2019 8:54 AM | |
Joined: 5/3/2017 Last visit: 5/21/2024 Posts: 673 Rating: (217) |
Hello ALAE, with the Feature bit 30 of channel blocks you can activate the de-energized value for block-external simulation.
The default setting is 1. More information about the Feature I/O you can find in the manual PCS 7 Advanced Process Library in the section Configurable response using the Feature I/O. With regards |
