7/30/2019 2:37 AM | |
Joined: 9/9/2015 Last visit: 10/8/2024 Posts: 727 Rating: (278) |
Can you screenshot in netpro editor? Probably there is something wrong in netpro. the s7 connection for server and standby should be identical. Then do a download again. |
Please give me 5 stars Rating if my post is helpful for you. :) |
7/30/2019 5:10 AM | |
For your case, I guess the problem happened in netpro editor or physical connection at standby server only. There might be a condition, when you configure in Engineering station (ES) and your ES doesn't have the same network adapter with OS Server, for example, CP1623 installed in OS Servers but industrial ethernet installed in ES, then you will need to reselect the channel unit from industrial ethernet to CP1623 in the target Stations WinCC Explorer- Tag management - System parameter. |
