9/13/2013 6:43 PM | |
Joined: 8/31/2005 Last visit: 6/14/2024 Posts: 2198 Rating: (326) |
I don't know, just syntax. I have itfrom a training (ST-7PRO2), I visited years ago. Later I used itin a application and it worked. And after I read your question, I just looked there, who I did it. Ok, I now searched a while and found out it's a "Pointer for Memory-Indirect Addressing" You can find it here: http://support.automation.siemens.com/WW/view/en/45531107Chapter 27.3.4.3 The example in the manual uses "L P#x.y" to load the pointer into ACCU1 I made it with the first two lines instead. And in my way the the bit-address is x.0. |
Last edited by: miami at: 9/13/2013 6:44 PMcorrected spelling Last edited by: miami at: 9/13/2013 6:43 PM |
