3/30/2009 2:58 PM | |
Joined: 10/10/2007 Last visit: 4/25/2024 Posts: 20 Rating: (3) |
have you tried putting you objects in a high-numbered layer on your template (i.e. layer 31) ? |
4/29/2009 2:35 PM | |
Joined: 5/27/2008 Last visit: 11/17/2024 Posts: 29 Rating: (0) |
Maybe a Siemens expert can clear this topic out? |
4/30/2009 10:36 AM | |
Joined: 5/8/2006 Last visit: 10/16/2024 Posts: 1085 Rating: (78) |
Hi The template screen isordered always behind a normal screen. "Picture in Picture" is only possible in WinCC and not in WinCC flexible. If you want to pop up an object in front of the screen, you have to insert the object in each relevant screen. If you use Faceplates, you will have the same procedure in each relevant screen. Maybe this FAQ will help you: http://support.automation.siemens.com/WW/view/en/24256007 Bye |
