9/28/2022 11:01 AM | |
Joined: 1/21/2013 Last visit: 9/26/2024 Posts: 3135 Rating: (489) |
Hi PHILCAT, yes, you can program a CPU 313C V3.3 (6ES7313-5BG04-0AB0) with STEP 7 Professional V17. To write data on the SIMATIC Micro Memory Card, you would need a SIMATIC Field PG or the SIMATIC USB Prommer. But unfortunately, the prommer is no longer available at Siemens. Maybe it's easier to transfer the program directly to the PLC. Since the CPU 313C does not have ethernet you would need some communication adapter like PC Adapter USB A2. Kind regards |
9/28/2022 11:11 AM | |
Joined: 11/25/2005 Last visit: 5/7/2024 Posts: 21 Rating: (0) |
Thanks for your answer, Stefan |
