6/7/2022 2:58 PM | |
Joined: 3/11/2019 Last visit: 10/15/2024 Posts: 1602 Rating: (293) |
Dear Amhed Abdelhak, is SIMATIC NET installed on the same system? If yes, this could be a possible reason. Please have a look this manual: SIMATIC S7-1500 S7-PLCSIM Advanced V4.0-> Problems after installing SIMATIC NET PC software products "After installing the SIMATIC NET PC software products, you may no longer be able to start the PLCSIM Advanced instances via TCP/IP." regards sancruz |
Feedback appreciated, please rate |
6/7/2022 7:21 PM | |
Joined: 11/14/2010 Last visit: 9/20/2022 Posts: 52 Rating: (2) |
Hi sancruz, Thanks a lot!! that was the issue! I have SIMATIC NET on the same system. I did an OS upgrade -in my case this was ok- per the link you provided and it fixed the problem. RemedyUpdate the operating system on your PC:
Thanks again! Regards :) |
Ahmed Elsayed |
