5/25/2021 10:56 AM | |
Joined: 6/19/2013 Last visit: 3/19/2024 Posts: 3 Rating: (0) |
Hi, Do you found a solution with VPN ? It seems I have a similar issue: PLCSIM communicates perfectly with a physical Modbus server on LAN, but I am not able to do the same thing over VPN / WAN. (Please see attached file). To switch between LAN / WAN tests, I change only then IPs addresses for server 1/server 2 in the client PLCSIM program and ModbusDoctor configuration. Any idea ? Is it possible ? Tkx ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 05/25/2021 14:17:05New subject after splitting |
