10/2/2020 2:58 PM | |
Joined: 8/27/2020 Last visit: 11/17/2023 Posts: 5 Rating: (0) |
Hello I am having the same problem that Gerskiy: Diagnostic status: "Module exists. faulty Differences were found between the loaded configuration and the offline project. The online and offline module configuration data are different. Online article number: 6ES7 841-0CC05-0YA5 Offline article number: 6ES7 314-6EH04-0AB0 Fault LED (SF) Fault LED (INTF)" When I suffered that at first time, I began the proyect at the beginning and.. This became to occurs again! I noticed that environment was in this situation: 1. PLCSIM in RUN-P mode. 2. I modified default value in for a variable in a instance-DB (initial seconds in a timer) 3. I tried to load software to PLCSIM while was in RUN-P mode. 4. PLCSIM was not able to re-run itselves. After that , my PLCSIM with this project doesnt works. Never goes out from SF error. What can I do? Have I to re-do my project again? ¿How can I reset the module has blocked -run? Thank you ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 10/05/2020 07:53:55New subject after splitting |
