3/6/2013 5:28 PM | |
Joined: 10/26/2011 Last visit: 7/22/2024 Posts: 762 Rating: (191)
Hello Samir_a, there is no way to use PowerTags in PCS 7. PCS 7 is based on the PO license system. Regards |
SIMATIC PCS 7 - Overview |
3/7/2013 8:42 AM | |
Joined: 8/15/2008 Last visit: 12/15/2023 Posts: 32 Rating: (3) |
Dear Thunderstorm, thank you for your reply. Then I need your help with PCS7 license. Could you please be so kind and review my attached PCS7 system architecture. Here Engineering Station with installed PCS7 v8.0 upd.1 software will be used for engineering of automation systems and operator systems. This ES will also operate as Operator Station. There are also 3 Single Operator Stations on the network. Please indicate what licenses will be required there for ES and 3 OSs ? Thanks in advance. Regards, Samir
AttachmentPCS7 arch.pdf (198 Downloads) |
3/7/2013 12:58 PM | |
Hello |
3/7/2013 1:10 PM | |
In the Siemens Industry Online Support you can find a application, in which your configuration is described. |
3/7/2013 1:23 PM | |
Posts: 836 Rating: (100)
You can use this config of course but I would prefer a server client solution but thats up to you. |
3/7/2013 4:16 PM | |
yes, the configuration will be same as described inStandard Architectures PCS 7 V7.1 SP2, page 31 of 5.1 "Multiple OS Single System"
