12/30/2009 9:14 AM | |
Joined: 9/16/2009 Last visit: 9/2/2024 Posts: 2 Rating:
Hello evryone, we have a problem, we need to removefrom STEP7CPU 414one ofcomponent (hardware), but when a make "station / consisten check" I get the error "configuration is inconstent". please find attached file. in the error descriptionwe foundthatwe usewrong group of addresses, howto find out whether there is really wrong adress group, and what the group can be used. and how to remove one component in this situation? The program we have received from the manufacturer, and never did not change anything: ( Our version of the STEP V5.4 + SP3 + HF1. Attachmentstep.zip (253 Downloads) |
12/30/2009 1:46 PM | |
thank you Wizard first what i found, that i can't change this size. also i found that cpu is not the same like in program. I change the cpu type, and only then I got permission to change. I changed the size, compile and download, but when i tranfer "Hardw.Config" i got "BUS error" on all Festo, which is a machine. I checked FESTO addresses, reset the CPU , but ... Attachmentst7.zip (191 Downloads) |
