3/19/2016 12:01 PM | |
Joined: 1/21/2016 Last visit: 6/24/2024 Posts: 43 Rating:
Dear Experts, I have Problem in Step7 Microwin SP9. In PG/PC it should have PC ADAPTER (PPI) in Set PG/PC (As attech in image_2).But in my system i can not access the option (As shown in image_1). I have try uninstalling and install the software again. And I am trying installing PC adapter USB v1.2 also.Still cannot Get proper solution about this problem. I am using this software in Windows 7 Ultimate SP1 32 bit. Please help me out of this as soon as Possible. Thank You in advance. AttachmentSupport.zip (1655 Downloads) |
3/19/2016 1:32 PM | |
Joined: 4/28/2015 Last visit: 2/7/2024 Posts: 10533 Rating:
Hello, try run this batch what is attached. If you want be sure, look at first to inside what kind of file is executing with parameter, because maybe file can be located on another place in your PC. Update: that exe is for x64 bit OS but probably existing same for 32 bit, maybe only with little different name. AttachmentSimatic_PGPC_Update.zip (2292 Downloads) |
Last edited by: Duris_I at: 3/19/2016 2:00:45 PMLast edited by: Duris_I at: 3/19/2016 2:15:20 PMWith best regards... |
