3/3/2008 1:29 PM | |
Joined: 8/31/2005 Last visit: 4/26/2024 Posts: 2197 Rating: (326)
Hello, please check if there is a hided connector parametrated with a "1" |
3/4/2008 5:34 AM | |
Posts: 12 Rating: (0) |
Hello, Miami Thanks for response. I am not clear about what you said. so i attatched property popup windows. please, look into them and reply. And one more, i did tried to add another [OR] logicincluded in same T4 task. but it did not work too. In case of adding [OR] logicincluded inT2 task, it looks working good. Thanks anyway. Attachmentproperty.zip (546 Downloads) |
3/7/2008 2:18 PM | |
You can set(unconnected) connectors to be invisible. If you rezise the colums in I/O you can read the headers. But your connectors are all visible: see attachment Please contact the Hotline with your problem. regards miami |
