7/16/2018 10:39 AM | |
Joined: 4/28/2015 Last visit: 6/3/2024 Posts: 3345 Rating:
Hi, if you have deployed a flow yet and after that the node-red crashed then you have an error in your flow. In this case it isn't possible to start node-red again because during the start this flow will be loaded again and node-red crashes again. The solution is to delete the flow on the IOT. How to do this is described here. Best regards! |
Not working for IOT2050 support anymore from March 1st, 2024. |
7/18/2018 11:11 AM | |
Joined: 6/19/2017 Last visit: 6/28/2024 Posts: 8176 Rating:
New question published by muthi is split to a separate thread with the subject How to read data from Modbus energy meter using Simatic IoT 2040?. Best regards |
