1/30/2013 1:50 PM | |
Joined: 8/25/2006 Last visit: 6/26/2024 Posts: 2207 Rating:
Hello. May be this is the problem of WinCC or PMC driver?.
Did you configure time synchronization between WinCC and TDC? You can make it through CP51M1. For this you need to run NTP-time-server on WinCC-PC (e.g. W32time or ntpd fromMeinberg) and configure in HWConfig this NTP-server. Also you need to insert RTCM-FB in your program.
2/4/2013 8:45 AM | |
Hello. If TS output is 1 this means there is no time-synchronization between PC and TDC-rack. You need to configure and run on PC some software that will act as NTP-time-server or use well-known NTP-time-servers from internet. You may use windows service 'Windows time' (W32Time), but first you need to configure it to run asNTP-time-server. Also you may use other software, e.g. NTP fromMeinberg. And don't configure time synchronization in WinCC. |
