3/25/2010 10:34 AM | |
Posts: 378 Rating: (47) |
Hello KoKoS, i am not expert on this topic, but i found a FAQ about Which HMI components can you connect with S7-200 CPU and what should you watch out for when doing so? Maybe this is helpful for you Best regards bilao |
3/25/2010 10:41 AM | |
Posts: 9 Rating: (0) |
Thank you bilao, I have read it and test everithning I found there. Still have problem... |
3/25/2010 11:21 AM | |
As i already mentioned i am not expert on this, but maybe i could be helpful to know which CPU you have. best regards bilao |
3/25/2010 12:21 PM | |
CPU 224 REL 01.22 Thank you |
3/25/2010 12:31 PM | |
Joined: 4/24/2006 Last visit: 10/14/2024 Posts: 8745 Rating: (1168) |
Hello KoKoS, Have you seen this link: What should you watch out for when using the RS485 repeater in PROFIBUS and MPI bus systems? See max. length of MPI cable. Best regards, Wizard |
3/25/2010 12:43 PM | |
Does your CPU have only one or does it have two interfaces? |
3/25/2010 12:48 PM | |
Only 1 interface (on CPU) and 4 extra modules (1 Digital Inputs and 3 Analog Outputs)
