12/6/2023 9:14 AM | |
Joined: 1/11/2019 Last visit: 7/1/2024 Posts: 727 Rating:
Hello Silva, The following link show you how to insert and configure OS servers in the project: |
12/7/2023 3:55 PM | |
Joined: 3/21/2015 Last visit: 6/5/2024 Posts: 36 Rating:
Hello, I want to share my solution here, now it seems to work fine the download to the OS server. The issue was in the beginning my project designed to have a single station ES/OS and i did opened the OS runtime in the ES computer, so if you want to test the OS on the ES computer please make sure use simulation and not the runtime. In case you ever run the Runtime in the ES and want to use a separated server later on please refer to the document in the link below, remember after you do the modification you should restart your PC, took me a while to learn it. After that the download from the ES to the OS went smoothly and the files were downloaded to the shared folder between ES and OS server https://support.industry.siemens.com/cs/us/en/view/24285161 Thank you for the help, very much appreciated. Silva |
