4/13/2007 1:22 PM | |
Posts: 2 Rating: (0) |
I´m trying to do a program for controlling a filter. Attachmentfilter.zip (1022 Downloads) |
4/13/2007 3:18 PM | |
Joined: 1/5/2007 Last visit: 4/7/2023 Posts: 1690 Rating: (580) |
Hello Jockes, that is easy. Look at the attachment. The Timing parameters must set/correctfrom you. Best regards Betel AttachmentCircuit Diagram2.zip (1061 Downloads) |
==> Meine TAG-Listen: "deut." |
4/18/2007 9:47 PM | |
Hello Jockes, ok, i hope, that i have now understand you correct. Look at the attachment for my new version. I have a complet solution for you with some comments and i have add some options (marked magenta). I hope you can use this funktions (Softkeys and display). Only the timing parameters of the 7 red marked units between every pair of outputs must set/correctfrom you! Start the simulation and look how it works. Best regards Betel AttachmentCircuit Diagram7.zip (949 Downloads) |
