5/17/2016 7:50 AM | |
Posts: 4 Rating: (0) |
Good day. Have a problem with download project to PLC s7-1214: "Modules with active test and commisiioning function can prevent the download process". |
5/17/2016 9:03 AM | |
Posts: 1529 Rating: (202) |
Means you probably are monitoring a program block or have something else online. |
5/17/2016 4:53 PM | |
In PLC were Force Values from previous project. Problem solved by erasing FV |
7/11/2016 10:08 AM | |
Joined: 9/3/2014 Last visit: 3/13/2019 Posts: 4766 Rating: (122) |
New question published by shivsang is split to a separate thread with the subject Check supporting TIA portal for PLC. Best regards |
