7/17/2012 9:29 AM | |
Posts: 3609 Rating: (29) |
Import of a Technical Question of the User Struggler
9/6/2012 2:47 PM | |
Posts: 1 Rating: (0) |
Thank you for your Reply, After configuring the GSD file for the IM 153-2 by the GSD tool which I download it from Siemens web site the status right now for the IM 153-2 leds as the following: SF=Solid Red BF1=Off BF2=Red Flashing the led status on the FDC, DP=on and the PA=flashing!! as per the manual I have to check the configuration or the addressing & connection, I'm already getting reading from the tembperature transmitters over the PG by using the Field Care from E+H. Please see the attached gsd file that I'm using. Attachmentsip58052.zip (67 Downloads) |
