3/6/2024 9:51 AM | |
Joined: 4/28/2023 Last visit: 6/23/2024 Posts: 1 Rating:
Hi i'm arun i hope you good i got a problem with "registered cpu for debugging'' this problem coming from last one week then i though we did change something somewhere else so we have to compile & download once like that and i try it many time but the problem didn't get clear again when ever i go for monitoring mode its popup that window like cpu registered debugging....But today i compiled and download it now the problem has been clear.....my doubt is what is the issue why the windows popup last one week then how its clear ------------------------------------------------------------------------------------------ |
Last edited by: The Helping Hand at: 03/06/2024 12:55:52New subject after splitting |
3/6/2024 10:03 AM | |
Joined: 3/14/2008 Last visit: 7/11/2024 Posts: 2075 Rating:
Hi, This happens when a change has been made in CFC, but the change is not downloaded to the CPU. When you go online, you will get the warning message. After download of the CPU, it is cleared. This also happens in other occasions for example when you save a VAT table. |
Last edited by: Oreca at: 03/18/2024 17:33:44If I could help you, you can use the RATE button. Thank you. |
3/18/2024 12:06 PM | |
Joined: 10/30/2018 Last visit: 7/8/2024 Posts: 8 Rating:
Hi AutoGen_5935769, In addition to @Oreca whenever symbol table changes, you will get the pop-up as "Register CPU for testing". Thank you. |
