11/12/2016 4:14 PM | |
Posts: 3 Rating:
hi sirs, i have problem with rotary object in wincc pro( tia v13) i not found feature same as wincc 7. you can support for me thank! ------------------------------------------------------------------------------------------ |
Last edited by: Min_Moderator at: 11/14/2016 3:43:40 PMNew subject after splitting |
11/30/2016 9:11 AM | |
Posts: 648 Rating:
Dear con ga, you can use TIA openess and the rotation tool of the HMI Toolbox. Look at this hyperlink - Chapter: Simplified Engineering: https://support.industry.siemens.com/cs/ww/en/view/106226404 With best regards rh1990 |
