7/1/2020 10:21 AM | |
Posts: 1 Rating:
Good day, I am having problems getting data from an S7-1200 to the IoT2040. The data block has "Optimized block access" unchecked and "Permit access with PUT/GET ..." is checked. Find Attached export of node-red flow. Any help will be appreciated. Error msgs received include "No response from PLC, Restarting communication" or "Failure (Bad values)" AttachmentNodeRedFlow.txt (182 Downloads) |
