12/13/2019 10:49 AM | |
Posts: 3 Rating:
Hello, I have a problem with the address of DB. instead of DB2.DBX10.0 I have DB2.??? ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 12/13/2019 12:27:15New subject after splitting |
1/14/2020 10:28 AM | |
Joined: 12/27/2018 Last visit: 7/19/2024 Posts: 510 Rating:
Go to the properties of DB2, attribute section, uncheck Optimized block access. Then compile the block. You will see the absolute address of each tag in offset section. For eg: i.e %DB2.DBW538 You can call each bit of a tag of un optimized DB to project. For example: %DB2.DBX538.0 to %DB2.DBX539.7 |
Jinson Kurian Vilayil James, P.Eng, BE, M.Tech (Power Electronics and Power System),PGDM, MBA |
1/14/2020 8:54 PM | |
Joined: 9/21/2012 Last visit: 9/11/2024 Posts: 4131 Rating:
The screen shot was already taken from a non-optimized DB. And the question was how to get the offset visible. After a non-optimized DB is modified, a compilation is necessary in order to see the offset. |
