5/22/2019 12:04 PM | |
Posts: 13 Rating: (0) |
I installed wincc flexible 2008 sp5 on Windows 10 64bit. when i open it, it does not work . I installed Automation License Manager. Please help me |
5/22/2019 12:13 PM | |
Joined: 5/12/2006 Last visit: 8/5/2024 Posts: 22334 Rating: (3000) |
Hello, which Windows 10 build version you use? Which Licence Manager version you use? Christoph |
7/25/2019 2:54 PM | |
Joined: 8/3/2009 Last visit: 8/6/2024 Posts: 13467 Rating: (1704)
Hello I think ChristophD is on the right path!! The WinCC fexible 2008 Sp5 installation files and the included ALM Version are a few days old... and I think you use a newer Build Version of Win10 So deinstall the ALM -> do a reboot of the PLC -> Install the Versoin out of this FAQ: https://support.industry.siemens.com/cs/de/en/view/114358 Then restart again and it should work! Bye Murof |
Last edited by: Murof at: 07/25/2019 14:55:32If this Information really helps, you could use the Rate function |
4/29/2020 12:28 PM | |
Hello newatsimat do you have tried my suggestion in my last post here?? Please Try and give us a feedback, and also Answer the questions of christophD There is also an Upd2 for WinCC flexible 2008 SP5 you should install it! LINK Bye Murof |
Last edited by: Murof at: 04/29/2020 12:30:05If this Information really helps, you could use the Rate function |
6/17/2020 3:54 AM | |
Joined: 12/6/2011 Last visit: 10/3/2023 Posts: 4 Rating: (0) |
Hello, It's Windows 10 Pro 64bit Automation License Manager Version 5.3 +SP4 +UPD1 64bit Edition. Regards Newatsimat |
6/17/2020 4:10 AM | |
Hi Murof, Thanks a lot!. It's done by your suggestion! Regards Newatsimat. |
