12/4/2015 4:32 AM | |
Joined: 4/10/2015 Last visit: 6/18/2024 Posts: 6 Rating: (0) |
Hello Miguel, I'm working in a project using a CPU 315F-2DP as a slave and a Hilscher card PCI CP50 as a Master, but I can't configure it in TIA PORTAL and I was wondering if you could find a solution for this. In the case you have had successful. Can you tell me how you did it? I Couldn't find a solution for this.
I will really appreciate it. ------------------------------------------------------------------------------------------ |
Last edited by: CS Moderator at: 12/4/2015 12:58:12 PMNew subject after splitting |
12/4/2015 2:08 PM | |
Joined: 3/5/2014 Last visit: 8/5/2022 Posts: 5521 Rating: (1054) |
hi, what exactly are you unable to project in TIA? The CPU or the PCI-Card? What CPU do you have exactly? MLFB? Maybe TIA is not supporting it. See following FAQ: Which devices and modules are supported by STEP 7 Professional and WinCC Professional in the TIA Portal?regards, |
FCK WAR! |
