5/29/2011 1:08 PM | |
Joined: 3/24/2009 Last visit: 7/9/2024 Posts: 535 Rating:
Dear Nashwa_459, I see two possible software-versions to configure your hardware:
The V11-version is a bit more intuitiv to use and also has a quite good help-function. The hardware you need strong depend on your requirements, but typically a CPU 3xx-DP can be used as controller. As I/O there's quite a big range of available modules - so I'd need some more details about your plant. Hope this helps. Best regards, yy1 |
5/29/2011 2:28 PM | |
Posts: 204 Rating:
Realy I don't know how to thanks you all, [snip] ... Thanks second question split to: profibus help - modules with ET200S |
