6/29/2007 8:01 AM | |
Posts: 112 Rating:
I highly recommend using FB125 for diagnostics of a DP slave. This block calls many SFC's including SFC13. Siemens has sample projects which include OP screens, saves you a lot of work. Entry ID:5362473 https://support.automation.siemens.com/WW/llisapi.dll?func=cslib.csinfo&objId=5362473&objAction=csOpen&nodeid0=16599820&lang=en&siteid=cseus&aktprim=0&extranet=standard If you do not have a SFC that you require in your project you can also use File, Open, then open the Standard library. Find the block that you want and then copy & paste. |
