6/8/2014 8:12 PM | |
Joined: 7/2/2008 Last visit: 7/2/2024 Posts: 928 Rating:
Hellomef3000, 1- If you have a bus connector with PG socket, Try to use it on the CPU's DP port and connect your PG to this socket. 2- View accessible nodes. 3- If you don't see any nodes other than the CPU then you have something wrong. It could be your cable or your sockets or maybe wrong connections (i.e. wrong IN and OUT or switched red with green and green with red). 4- If you see the same addresses you have configured in HW configuration then you have a problem with your GSD files. I mean you probably used the wrong GSD files for your UMGs. Best regards, H-H
